How can I wrap a sketch that I want to use as an extrusion path to a cyilnder?
jeremy_lee540
Member Posts: 9 PRO
in Drawings
I have a curved cooling surface that will have tubing welded to it and there doesn't seem to be a way to lay the extrusion path sketch onto the surface with the wrap tool. Something I'm missing?
Optionssteve_shubin Member Posts: 1,070 ✭✭✭✭@jeremy_lee540
Does this help
https://cad.onshape.com/documents/39ff0172b030db66660327d7/w/c6dcc00f28fe2ba63ec4f6ae/e/b47fb2eeb2e072eee4227418
Wrap needs an enclosed area within a sketch to wrap
2
It sounds like you need the Sweep feature. Or Sweep normal by @mahir.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
Does this help
Well I think it's good you brought up SWEEP right off the bat
