How to make a Scotch Yoke Mechanism
Anmol_Sekhon
Member Posts: 2 ✭
Hi there! Was wondering how to create a scotch yoke mechanism? I've tried both pin slot mate and tangent mate but can't seem to get it to work. Anyone have any ideas about this sort of mechanism? Not much on the web about this topic.
Here is what I'm working with and I want that grey pin that is in the blue wheel to be in the other grey part and want the motion to be side to side:
https://cad.onshape.com/documents/be5945925f9befff0067f727/w/504bd68762f0420ca9c34b2f/e/b16f929d7a01f9e08e04f4bd
The one constraint for this to work is that the "z" axis has to match for the pin slot so once you add "real world" manufacturing clearance it can be a bit trickier, the best way would be to define a pair of explicit mate connectors (assuming the parts are modeled in the same part studio with the correct clearances.
Or if that's not possible you can use the "extra sketch" trick as shown above but change the "crank pin center" mate from a "revolute" to a "cylindrical" mate and then it can handle axial mis-alignment.
https://cad.onshape.com/documents/de9727ecc28a568a041dcead/w/6b25da7c4b7956ac39324d86/e/a033faff5dfc13b2a9a2e488
Just mates, no extra sketch
Created the following IR: https://forum.onshape.com/discussion/18747/new-slot-mate-variation/p1?new=1
https://cad.onshape.com/documents/be5945925f9befff0067f727/w/504bd68762f0420ca9c34b2f/e/b16f929d7a01f9e08e04f4bd?renderMode=0&uiState=62e054a932824b2a0d05927d
This allows the slider to move along Z. In order to not be stuck in the Z direction, you either need the point sketch intermediate part or allow the pin to be a separate part that rotates relative to the crankshaft...
It looks like @Anmol_Sekhon has the pin as a separate part already so if the pin can be allowed to rotate the planar mate (with realigned mate connectors) in this example would work.
