Internal or External Surface Selection
chris_ICL
Member Posts: 2 EDU
Hi, I am learning how to use Feature Scripts and I have come up against a bit of a road block that I'm sure must be relatively easy to solve:
I can't figure out how to tell whether a user selected surface is an external or internal face (for example a cylindrical surface could be either a hole or a shaft).
Please could someone point me in the right direction?
Thanks,
Chris
Thanks,
Chris
Just in case this isn't obvious, you will also need to make sure that the body is solid. If not, the surface normals could be deceiving.
const curvatureResult = evFaceCurvature(context, { "face" : qFace, "parameter" : vector(0.5, 0.5) }); const isExterior = curvatureResult.maxCurvature > 0 / millimeter; // const isInterior = curvatureResult.minCurvature < 0 / millimeter;
