How to do extrude cut or similar?
CSC65
Member Posts: 4 EDU
Hi folks. I'm trying to model a train's sand dome which sits on top of a round boiler. I would like to cut out a flange to sit on top of the boiler, which the dome sits on top of. How can I cut out the flange piece?
See video example here @2:40: https://youtu.be/Xfv6L9jD988?t=174
The OnShape model is here: https://cad.onshape.com/documents/de5c33edf5a6d69bd3590039/w/b19e20837afdfed0f287276c/e/b93f843a543d8b5c2dd3546d?renderMode=0&uiState=62e354401e8eaf63aa69d03a
I'm migrating to OnShape from another well-known CAD program, and so far I'm really liking it.
Thanks!
Chris
OptionsCSC65 Member Posts: 4 EDUI was able to solve the problem using boolean intersect. As long as the geometry is clean, I don't really care how I get there.Thanks again.C.0
https://cad.onshape.com/documents/ba04993421326371612f786a/w/43f92c648deb9477e502c96a/e/75f831259b2bd25a6686e62f
I did not use a loft to make the fillet
But at the 7 minute and 50 second mark in the video, he says that the longer fillets are not tangent
The way I did it it’s all tangent
The difference is, doing it the way I did, the top of the fillets are not all at the same elevation when you go around the entire circle
But if you wanted it like he did, yeah you could do it that way. You could do a loft to make what looks like a fillet
Here's my attempt:
https://cad.onshape.com/documents/4f3df1d6c5cc0460c861a4af/w/9b13a1092342b980cd248597/e/21bacc68fe74ff486e3bcc6f
https://cad.onshape.com/documents/4f3df1d6c5cc0460c861a4af/w/5280f9235f1df31608d4d507/e/5e27b3fd8e88249582c4b88a?renderMode=0&uiState=62e41da9b15a2f276b663ca4
