All drawings in one sheet
jacek_zagajajacek_zagaja Member Posts: 47 ✭✭
Solidworks part file imported into Onshape. When you start a drawing you select sheet size and part or its component. When you choose a whole part then you cannot add particular component of the part - you need open another drawing. No chance to put all part components in one drawing?
    @jacek_zagaja, consider inserting your "parts" into an Onshape "assembly"  Then generate a drawing of that assembly.  Does this approach suit your purpose?
  • eric_pestyeric_pesty Member Posts: 2,276 PRO
    Or you could create a composite part in the part studio if what you have is just multiple bodies that should be a single part.
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 103 PRO
    Sounds like you want to either create a composite part (in the part studio) or an assembly and then make a drawing of that instead.
