Create a query from a Z_AXIS
I am using circularPattern in FeatureScript. It requires the axis of rotation as a query. I want to rotate around the Z_AXIS. How do I convert the Z_AXIS into a query?
Example here:
For patterning bodies and faces, this should produce the same result as using 'circularPattern'. A benefit is you aren't restricted to rotations about an axis.
Independent Onshape Consultant | Industrial Designer
default features should always exist. I am not saying this is the way to do it, but it is a way to do it.
qTopPlane(EntityType.FACE);
but you can also simply do this.
plane(vector(0,0,0)*meter,vector(0,0,1));
or
or even faster
plane( WORLD_ORIGIN,Z_AXIS,X_AXIS);
and even faster yet
{"origin":WORLD_ORIGIN,"normal": Z_AXIS,"x": X_AXIS} as Plane;// this i believe bypasses the plane function to normalize already normalized vectors.
