Adding a fillet to an inside corner,
 colin_king506
                    Member Posts: 44 ✭✭
colin_king506
                    Member Posts: 44 ✭✭
                    I am trying to add a fillet to an inside corner, bur all tutorials found are showing on older software. I am using the version download about a month ago.
             Axel_Kollmenter
                            Member, pcbaevp Posts: 436 PRO
                    Hi, just select the fillet tool and then select the edge you want the fillet on. With Onshape youre always using the newest version, there is no download. Its a cloud based program. Axel_Kollmenter
 Best regards,
 Axel Kollmenter1
             colin_king506
                            Member Posts: 44 ✭✭
                    I would like to add - https://cad.onshape.com/documents/77671fecc20b2f6596ce149f/w/953f675e42a2e25ff57100ee/e/d994425a9382e04bfa78bea2. colin_king506
                            Member Posts: 44 ✭✭
 I could edit the sketch, but I was looking at changing it here. I will probably go to editing the sketch and extruding it as one piece instead of marrying 2 rectangles.0
Axel Kollmenter
