Difficulty with defining a volume parameter
Matthew_Wilson
Member, csevp Posts: 5 PRO
I'm writing a feature that takes a volume measurement from the user. I'm running into trouble with the isVolume predicate:
FeatureScript 1821;
import(path : "onshape/std/geometry.fs", version : "1821.0");
annotation { "Feature Type Name" : "My Feature" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
annotation { "Name" : "My Volume" }
isVolume(definition.myVolume, VOLUME_BOUNDS);
// Define the function's action
The volume definition throws the warning: "Expected parameter id to be defined as a field on val" I have zero idea what that means. I don't think that I'm using it wrong, it's documented here: https://cad.onshape.com/FsDoc/library.html#isVolume--VolumeBoundSpec This is just the same as a Length definition, what am I missing?
If you want to input a volume, two possible workarounds are:
I was confused because the docs seem to indicate that you can use isVolume in this way. Maybe we can get an improvement request to add a volume parameter to the UI? ;-)
