STEP vs Parasolid for Export/Import
matthew_stacy
Member Posts: 489 PRO
in General
What are the relative merits of STEP and Parasolids for export from and import to Onshape? For parts? For assemblies?
Neither file format seems to carry any attributes other than appearance through the export/import process.
In general, for importing to Onshape, the Parasolid format will be the preference... but it does depend on the source CAD system's method of writing the x_t (are they using native tools, 3rd party tools etc)
@S1mon, for the case of two platforms built on the Parasolids kernel can you provide any examples of geometry that a Parasolids file can deliver that STEP would miss? Have you actually encountered limitations with STEP or is this theoretical?
