Is there a systematic way to diagnose "Sketch could not be solved" error?
john_lombardo
Member Posts: 20 EDU
What should be checked and in what order?
Along the lines of what @S1mon said
My feeling is — don’t work in red AT ALL. As soon as you see the very first thing go red, immediately undo. Then give a second try, only this time, hold down the shift key
Why things go red — can often be an extraneous auto constraint kicking in, that was not useful / necessary / or wanted for what you were trying to accomplish at the time
You can temporarily disable the auto constraint function by holding down the shift key
But the problem is, you won’t be able to AUTO snap together the ends of lines, for one thing, when you do this.
But there is a solution, and that is to manually set the constraints, if things are turning red when you work with auto constraints
So what you would do is, move the two endpoints within close proximity. Then select the two endpoints, and then go up and select the coincident constraint WHILE HOLDING DOWN SHIFT. In other words, make sure you are first holding down shift, before you select the constraint you want to use
But note that if you see something go red, and you continue to work in red conditions, you’re just making it harder and harder on yourself to correct things later on
Another tip is, keep your sketches simple. Don’t try and do everything in one sketch. Don’t try and put 1 billion different elements in one sketch. Break it up into multiple sketches.
Try to limit the amount of vertices. Instead of using a bunch of points to make a curve, make sure you know how to use the arcs, spline and Bézier tools to where you don’t have to use so many points along a curve. This could help in keeping an unwanted extraneous auto constraint from kicking in, by limiting the amount of vertices that the auto-constraint function has to act upon
You can certainly make a complex part, by using a number of simple and sparse sketches.
The term that Onshape uses for what happens when you hold down SHIFT is, that it SUPPRESSES INFERENCES
Suppressing inferences, is another way of saying that the auto constraint functionality is disabled - IN PART
IN PART, because when inferences are suppressed, certain constraints will still be created automatically. Such as when you create a rectangle, the segment endpoints that make a corner, will be coincident, and at least one segment of the rectangle will be horizontal. But with inferences suppressed, you won’t be able to automatically snap to the elements of other objects
When you’re using the Onshape mobile app, the way you suppress inferences is, by accessing the contextual menu by doing a two finger tap on the screen, which will bring up a menu where you can select — suppress inferences. And the inferences will stay suppressed until you either turn inferences back on, or until you exit the sketch your working on
Thank you for your suggestions. Here's a link to the drawing. Sketch 21 is the one in question. I might have gone too far with too many edits and at my experience level do not see the issue(s).
The extrudes work and the part exports to an STL which prints fine, so it appears that the sketch not being solved has no effect on the printed part. I don't understand why Onshape finds fault, doesn't reveal exactly where the fault is, but yet exports an STL that's fine.
I spent time looking at this sketch
There are numerous other things I would do to make this more stable
But this should give you some idea of the process
FOR STARTERS -----
Wiggle things
If things are moving to where lines are no longer horizontal,
then UNDO
and apply the horizontal constraint
After a wiggle
If you see that the end of 2 lines are no longer making a proper corner
then UNDO
and apply a coincident constraint to the 2 endpoints
So on and so forth
