Adding a fillet to an inside corner,
colin_king506
Member Posts: 53 ✭✭
I am trying to add a fillet to an inside corner, bur all tutorials found are showing on older software. I am using the version download about a month ago.
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Hi, just select the fillet tool and then select the edge you want the fillet on. With Onshape youre always using the newest version, there is no download. Its a cloud based program.
Best regards,
Axel Kollmenter1 -
colin_king506
Member Posts: 53 ✭✭
I would like to add - https://cad.onshape.com/documents/77671fecc20b2f6596ce149f/w/953f675e42a2e25ff57100ee/e/d994425a9382e04bfa78bea2.
I could edit the sketch, but I was looking at changing it here. I will probably go to editing the sketch and extruding it as one piece instead of marrying 2 rectangles.0
Axel Kollmenter
