Gravitational forces
bert_fourie
Member Posts: 103 PRO
in Simulation
Is there a way to add gravitational forces? It would be useful to switch that on or off.
Yes, you can use the acceleration force and it already has the default value of the earths gravity.
But you have to add the acceleration for each body!
You also have to make sure that the arrow is showing down. That depends on the Load Direction selection.
The direction can be flipped with the arrow button behind the Load Direction box.
Some improvement ideas:
https://cad.onshape.com/documents/75c8da324b46027376069b15/w/495dcead94f29bbfe588748c/e/c3165efa02796fdbc29c9313?renderMode=10&uiState=6308ab5487e7544a3d50eeb9
