select a line under a line
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
How can I select a line which is hidden under an other line?
Best regards,
Axel Kollmenter
  • MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
    edited August 2022 Answer ✓
    Pressing "~" to cycle through the select other is the best way I know.
    Every once and a while I have to select both lines, with an inclusive box selection, then deselect the one on top. This can be useful for drawing studios sometimes too. Or you can exclusive box selection around the smaller line if that is the one you are after.
    RENDERCAD
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 481 PRO
    @Axel_Kollmenter
    German users can use the keyboard button Ö
  • jose_pedro674jose_pedro674 Member Posts: 11 ✭✭
    right-click and choose, "select other".
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    edited August 2022
    I know this but, it wont show the right line. It only shows me the edge of the part.
    Thank you anyways
    Best regards,
    Axel Kollmenter
    RENDERCAD
    Alright "~" doesnt work for me but the selection box is a great Workaround! Thank you Michael
    Best regards,
    Axel Kollmenter
    @Axel_Kollmenter
    @sebastian_glanzner aah perfect! Thank you :) I love shortcuts haha
    Best regards,
    Axel Kollmenter
    @MichaelPascoe, inclusive select and then deselect the top entity is a great tip.  Thanks for that!
     B)
    RENDERCAD
