Accuracy of Results
bert_fourie
Member Posts: 101 PRO
in Simulation
I did an analysis of a roughly 12m long assembly. The von Mises stress results came in a lot higher in certain localised areas compared to my traditional FEA solution Simsolid, whereas the overall deflection was virtually the same. To be sure I then ran the same analysis in Simscale whose results corresponded closely to Simsolid. I tried changing connection types and added in some corner chamfers but that did not change the results much. The overall distorted shape looks correct and the deflection corresponds closely to the other FEA's. I wonder if this is a function of the size of the structure and the algorithms used that the local stresses may not be calculated correctly on such a big structure. I know there was an earlier comparison run on a smaller object reported in the forum. Would you please comment? Happy to share the file.
Could you post a screenshot to help illustrate the issue? As of now, the default behavior should be that any pair of contacting parts is fused (fastened) where they touch - unless otherwise mated. If mated, the corresponding DOF will be honored over the interaction region.
I agree that mates should be enriched for simulation with friction and displacement/rotation limits, but that will not happen until we add more sophisticated solvers. Until then, mate limits do not inform the simulation boundary conditions, so the linear static results may not be accurate unless the Assembly is fully constrained to begin.
Though the solver is robust to Assemblies in static equilibrium, but not fully constrained, a slight imbalance during the solve can drive toward unstable results. Enhancing simulation with load stepping or rigid body dynamics could help mitigate this, but we are not ready to implement those technologies at this time.
Best,
Chris
Without the pictures, it is difficult to appreciate the scale of this thing. How did you model all of that plate steel? Are they separate parts? One solid part? Or did you manage to do it in a sheet metal model?
-Chris
Thank you for the clear explanation - I have a much better understanding of the system. Congratulations on the first use of the machinery and your mitigation strategy, very well done!
From the analysis side of things, I can say that our adaptive scheme will refine on hot-spots regardless of how you constructed or mated, but the model will be overall more refined as large parts are subdivided into smaller assemblies. In this case, I completely understand the hassle of having to mate each and every section. One thing you could try is splitting the geometry into parts in the Part Studio and then Grouping them in the Assembly. As a Group, we will still treat each of the parts individually, and you won't have the trouble of assigning Mates to each pair.
Having said that, you and I did discuss a future capability whereby you identify certain faces as important and we add additional fidelity/precision to that segment of the mesh. For anyone else reading this thread, I'd be interested to know if that sort of feature would be helpful for you too, and what you think would be the least obtrusive way to identify those regions of interest.
Best,
Chris
