Problems with Patterning Holes
Hello All,
I'm attempting to pattern an unknown number of linear holes in a parametric part based upon the object's height (holes 2 inches apart, beginning and ending at least 4 inches from each end of the part. The math is simple : floor((#height-8in)/2) would give me the number to duplicate, but I can't seem to get this to work in a variable or propagate it to a linear feature with hole. Part of my problem seems to be that I'm trying to turn an object in inches into a unitless number but I can't find a function to allow that. I'm probably doing something stupid. Can someone direct me to the right way?
Thanks
Thanks
(#height - 8in) / (2 * inch)
You could also use the excellent "linear pattern plus" custom feature that lets you do this and more without having to do the math.
https://cad.onshape.com/documents/1196579d97167d7a348652a9/v/4c8563e8233b4395cd866e1a/e/eded24da9efe0d8bf1929410
