Function variables
james_sleemanjames_sleeman Member, Developers Posts: 21 ✭✭
It would be super useful to be able to define a variable as a function, so that we could do something like
#myFunctionVariable(5)
where
#myFunctionVariable(x) = [equation involving x]
use case for example would be in having some standard and centrally configurable adjustment for hole sizes, to achieve dimensionally accurate holes on 3d printers without having to hard-code in your printer/filament's peculiarities we could just dimension our 3mm holes to #hole(3) such that the #hole(x) variable was defined as an equation that produces the correctly adjusted dimension.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,248 image
    edited May 2016
    With FeatureScript released, you can now do basically this, just using a Feature Studio.  Create a custom feature with code like this:
    annotation { "Feature Type Name" : "Add My Functions" }
    export const addMyFunctions = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            setVariable(context, "myFunctionVariable",
                function(x) {
                    return x + 2 * millimeter; // Function code goes here
            // You can make more setVariable calls here to make more functions
    And then in your Part Studio, add the "Add My Functions" feature at the beginning of the feature list.  You can then use #myFunctionVariable(2 cm) in a subsequent expression (to get 22mm).  Eventually we'll make it possible to just set the value by defining the myFunctionVariable variable without creating a Feature Studio.
  • pablo_fernandez_techpablo_fernandez_tech Member Posts: 5
    I tried this, but I get "Enter a valid expression" when I try to use the function:
    It's impossible to debug without a link to a public document.  A possible explanation is that your function is not returning a quantity with the right units -- it needs to return a length.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 168 PRO
    edited September 2022
    I was very curious to try this out and it turns out that there's a lot you can do with these functions, at least a lot more than I thought. They're a pain to debug and you miss out on the great snippet inserts you get in Feature Studios, but it's cool that things like for loops work in variables.
    Here's a variable that displays a decimal as a fraction (just paste this into the Value field of a variable feature).
    function(x){var wholeNumber = floor((x + 1e-11 * meter) / inch);var remainder = x / inch - wholeNumber;var fraction = 1;for (var i = 0; i < 8; i += 1){if (abs(remainder - round(remainder)) < 1e-11) { break;}remainder *= 2;fraction *= 2;}if (fraction == 1){return wholeNumber ~ "\"";     }  var fractionalPart = round(remainder) ~ "/" ~ fraction;if (wholeNumber == 0){return fractionalPart ~ "\"";}return wholeNumber ~ " " ~ fractionalPart ~ "\""; }
    This is definitely one of those "why would you ever do this" sort of situations, as it is way more efficient and simpler to just write a custom feature, but who knows there might be some cases where it's better to just use a variable. One could imagine a variable studio of functions that one might want to use often.
    chadstoltzfus@premiercb.com
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    This is definitely fascinating, but I agree that I can't quite picture the use-case where that's better than a feature. There probably is one somewhere though.
    If you're using Ilya's code above you need to add units to the number since you can't add a number, and length together. Try #myFunctionVariable(2mm) instead.
    The problem was that I didn't have a unit.
  • fstfst Member Posts: 79 ✭✭
    I cannot get this to work. Have defined a function as value of a parameter as shown by @chadstoltzfus. Now I try to call it, but it is always shown as invalid.
    Function definition: pipe_width_at: function(x){return pipe_height_at_bottom-(pipe_width_at_bottom-pipe_width_at_top)*pos/soundpipe_length;}
    ^^This still seems to work! (All variables inside this definition are defined above, they are lengths in mm. Couldn't define the function as length, it was accepted when I chose "any" though.)
    Attempts to instantiate the function:
    #pipe_width_at(#soundpipe_length+#soundhole_length)
    #pipe_width_at(245mm)
    #pipe_width_at(245)
    edited April 2023
    I think I found the answer: It is currently apparently not possible to reference other variables in function definitions.
    So this works:
    name: increment.  value: function(x){return x + 1};
    But this doesn't:
    name: startValue.  value: 42
    name offsetFromStartValue.    value: function(x){return startValue+x;)
    ^^these two can still be defined, but #offsetFromStartValue(2.0) will fail
    Thinking now about building a bigger (Featurescript)-feature that creates essentialy the entire part programmatically - might be easier.
    --- old posting ---
    #pipe_width_at(245)
    ^^ None of these seem to work.
    Any ideas?
    Removed link - not sure why my postings are not published when I post links to my public documents? Might have helped to understand the problem...
    @ferdinand_strixner
    To my knowledge there isn't a way to reference Part Studio variables inside the scope of the lambda function, though it's worth noting you can send a Part Studio variable as an argument to the function.
    Ex:
    name offsetFromStartValue.    value: function(x, y){return y+x * in;)
    Invoke #offsetFromStartValue(2in, #startValue)
    Will return 44
    Though you're probably right, it's going to be much more scalable and easy to manage to just make a custom feature.
