Show Part Intersections on Drawing Views
Can anyone shed some light on the thought behind having the "Show Part Intersections" toggled OFF by default when placing views on a drawing? It seems as though I am almost always changing views to "Show Part Intersections" in order to properly show the view. I have yet to see why this is even an option, let alone toggled "OFF" by default. For smaller scales/views, the difference between showing and hiding part intersections is not really noticeable. But for larger views/scales, the difference is obvious. I'm just curious as to why "Hide Part Intersections" would be favorable over "Show Part Intersections"?
The setting should only make a difference if you have parts that are interfering with each other, which would typically not be the "norm" (depending on what you are designing obviously...)
If you have to turn this option quite a lot in drawings you should reconsider how you design your parts/assemblies and actually do a boolean operation in the part studio before you create a drawing. Otherwise things like mass/volume/surface area might be incorrect for downstream operations.
