Determination of the volume
amir_livneamir_livne Member Posts: 85 ✭✭
Hi
I would like to create different solid bodies with the same volume
Is there any solution for it in Onshape?
Thank you
Amir Livneh
  • afalzate13afalzate13 Member Posts: 50 PRO
    If the shape is simple enough, perhaps the dimensions could be constrained using variables, otherwise perhaps a scaling custom feature script that can pull the variables needed from the part properties. What kind of shape in the solid in?
  • amir_livneamir_livne Member Posts: 85 ✭✭
    Hi
    I would like to create several different kinds of cans with the same volume
    If this is a cylinder you can probably set the desired volume as: #V=amount given, Radius as #R, and #H as the height, then either the height "H" = pi*(#R^2)/(#V), and type in a value for "#R", or use #R in terms of height as #R = sqrt(#V/(pi*#H))
