Create a query from a Z_AXIS
monroe_weber_shirkmonroe_weber_shirk Member Posts: 99 EDU
I am using circularPattern in FeatureScript. It requires the axis of rotation as a query. I want to rotate around the Z_AXIS. How do I convert the Z_AXIS into a query?
  • antlu65antlu65 Member Posts: 61 EDU
    edited August 2022
    I was wondering the same awhile back. I don't know if this helps, but you might consider using 'opPattern' with 'rotationAround' instead of 'circularPattern'. That's what I ended up doing.
    Example here:
    const axis = Z_AXIS;
    var Ta = [];   // Array of transforms to apply.
    var names = [];   // Array of instance names.
    for (var i = 1; i < n; i += 1)
       Ta = append(Ta, rotationAround(axis, i*360*degree / n));
       names = append(names, toString(i));
    opPattern(context, patternId, {
       "entities" : qEntity,
       "transforms" : Ta,
       "instanceNames" : names
    For patterning bodies and faces, this should produce the same result as using 'circularPattern'. A benefit is you aren't restricted to rotations about an axis.
  • monroe_weber_shirkmonroe_weber_shirk Member Posts: 99 EDU
    Thank you! This side steps the problem and is a great general solution.
  • EvanReeseEvanReese Member, Mentor Posts: 2,445 ✭✭✭✭✭
    edited August 2022
    The circularPattern feature is looking for a query, as you found. opPattern just uses transforms and is the better solution like you said. If you ever needed to get a query of a line for an axis you have to create the actual geometry and then delete it. You could make a sketch line on the front or right plane; a sketch circle on the top plane; a mate connector at the origin; or a 2-point fit spline. There may be others too, but generally opPattern will be easier to code (though less like actual modeling), and faster to regenerate.
  • Jacob_CorderJacob_Corder Member Posts: 137 PRO
    if you want the Top plane to get the z axis from, you can simply call qCreatedBy(makeId("Top"),EntityType.FACE)
    annotation { "Feature Type Name" : "top plane axis" }
    export const topPlaneAxis = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
           var topPlane = qCreatedBy(makeId("Top"),EntityType.FACE);
           addDebugEntities(context, topPlane, DebugColor.RED);
           var tPlane = evPlane(context, {
                   "face" : topPlane
           addDebugArrow(context, tPlane.origin, (tPlane.normal*25*millimeter) + tPlane.origin, 5 * millimeter, DebugColor.RED);
    default features should always exist.  I am not saying this is the way to do it, but it is a way to do it.
    Jacob, this is a long overdue response that got lost in my drafts! Thank you! This code is great. I think one of my challenges in writing FS code is that it is hard to know how to search for these code examples.
    I just noticed this also. you can just call
    qTopPlane(EntityType.FACE);
    but you can also simply do this.
    plane(vector(0,0,0)*meter,vector(0,0,1));
    or
    plane( WORLD_ORIGIN,Z_AXIS);
    or even faster
    plane( WORLD_ORIGIN,Z_AXIS,X_AXIS);
    and even faster yet
     {"origin":WORLD_ORIGIN,"normal": Z_AXIS,"x": X_AXIS} as Plane;// this i believe bypasses the plane function to normalize already normalized vectors.
