Loft with guide and path making a weird wave
Why is loft doing this crazy s#$%?
I could draw a nonplanar path for the top but I thought it would be easy enough as one solid piece.
(The model)
Here is the loft with the base curve to fit to.
If I add guides, the top doesn't follow.
A path gets the general idea right but I can't use 2 paths.
Combining both makes a weird wave.
(The model)
If you really aren't sure what those missing edges should look like, you might try lofting just a face at a time. Keep in mind that lofting from one straight line to another with one guide curve will give a different result than lofting the curve with two straight guides. You may like one better than the other. Once you've got the missing edges, you can loft that face, and then create the flat ends (use offset of 0 with the sketch, or create a fill surface).
https://cad.onshape.com/documents/76fb929696ca21c1ac9d86f4/w/08da4f8c9cbb8cfbfd8e68b1/e/1830a337975d29daaadb5dc1
Freeform Spline by Evan Reece
https://cad.onshape.com/documents/cd51f29c6937305f86a9df95/v/e7c4be973fdab957ca9c5497/e/44de484ba0acba52f99fcfc5
I messed with it and found that Simon's suggestion is best. I did separate lofts. If you need more control, then making a guide for each corner with freeform spline (or any other way you like) would be what you need. https://cad.onshape.com/documents/24f49100190c77289e7761df/w/7cd885f7dab14f951602271c/e/55e73bffa89321fe6279152b
It's not very well documented, but a couple key points:
This is the basic stern.
