What scale to draw an object for printing
john_sucharski
Member Posts: 4 ✭
I have a question with a part I designed and am having someone print for me. The part is a cylinder 12” (1’-0”) in diameter and 4” high. I’m assuming that in On Shape I’m drawing full size and not to a scale. The printed part is for HO scale trains which is a scale of 1/87. When printed, the diameter of the cylinder at HO scale should be 1/8”. He is using Chitubox for a slicer program. I gave him the STL file of the part to the size I originally drew it. He said it was too large and tried to scale it down in Chitubox and it didn’t work too well. I then scaled the part down in On Shape using the Transform function so that it was full size for HO scale. Diameter became - 1/87 x 12 in = .1379 in. I gave him the STL file and he said the part was way too small and would need to scaled up about 250% to be close to the 1/8” diameter.
So, do I need to draw the part full size (i.e. diameter 12”0”) or full size for 1/87 scale (i.e. diameter .137”)?
Thanks in advance,
John Sucharski
edward_petrillo
Member Posts: 100 EDU
250% = 2.5 times, looks suspiciously like an inch to metric conversion error0 -
eric_pesty
Member, pcbaevp Posts: 2,475 PRO
If you have information on the "full size" part I would draw it full size and use a scale (in the "transform") feature at the end.
You definitely want to send something that is the size you want to get it back at (i.e. export 1:1) to avoid issues.0
Then the only remaining question would be making sure there isn't a unit mis-match during the import process by whoever is printing but that would be dependent on the software and process they are using (as well as the export format used) but they should be able to handle that...
