Antenna cable coil
alex_hill864
Member Posts: 3 ✭✭
Evening, I'm looking for a bit of help with a cable coil. The part below has a coil of coaxial cable on it as part of an antenna system. The coil needs roughly 8 turns to reach its optimum.
The problem is I'm not sure how to blend the cable 'groove' I made using the helix tool so that the cable can be fed through a raised feature.Roughly shown below.
Just wondering how this might be done. I'm probably not asking right questions to identify the tool or method so could do with a bit of help please. The public file is here if you needed to see what I'd done so far.
thanks
Alex
glen_dewsbury
Member Posts: 1,284 PRO
Looks like the curve used to make the turn may not be set to well, Make sure it's normal to the end of spiral and follows through to the inside of the part, Should be able to select the curve with the spiral for one clean sweep.0
Sweep (onshape.com)
