Part number in cutlist
Hi there,
Wondering if it is possible to easily have part numbers in the onshape cut-list?  Know you can add "override columns" but from what I can see using this method would mean entering in part numbers manually.  We dont technically need part numbers for all frame members, just mainly looking to add part numbers for modified frame members (with holes, cuts, etc.) but would like to avoid manual entry if possible
Thanks,
Scott Martin
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 105 PRO
    My understanding is the cutlist is treated as the lowest level "part" in the Onshape BOM. As such, the individual members do not get detailed out with part numbers. I would agree though it would be nice to utilize the speed and rigid body nature of the composite frame while maintaining the ability to add properties to the individual members.
