Where can I find the meaning of the number in the transform property from the API?
kevin_dolfingkevin_dolfing Member Posts: 5
edited November 2022 in Community Support
Hello, I am doing a prototype with the OnShape API for an internship, which involves showing an assembly in GLTF on another webpage. So far I've been able to work my way through the API except this. When I get the data for an assembly I get a occurrences.transform property that looks like this:
<div>transform: [</div><div>&nbsp; &nbsp; 1,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; -0.11526866659459908,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 1,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; -0.02565412583836096,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 1,</div><div>&nbsp; &nbsp; 0.01184993247305625,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 0,</div><div>&nbsp; &nbsp; 1</div><div>]</div>
How do I know what these values stand for? I've looked around, but can't seem to find any definition for these. I assume index 3, 7 and 11 are x y and z respectively, but what about the other values.
Edit: Looks like the code block didn't get posted right. So here's a hastebin link: https://hastebin.com/nogivuporo.yaml
Edit 2: Further investigation leads me to believe that index 2, 6 and 10 represent the rotation, though these numbers don't seem to line up with radians, degrees or gradiens? Is there some catch with this?
  • caden_armstrong2caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    edited November 2022 Answer ✓
    The transformation matrix is a 4x4 matrix comprised of a rotation matrix, translation array, uniform scale, and i think non-uniform scale(? havent confirmed this, but it doesn't matter in most use cases).
    the indices
    0,1,2
    4,5,6
    8,9,10
    Are the rotation matrix.
    indicies
    12,13,14
    3,7,11
    are the translation array
    index 15 is the scale parameter (default to 1)
    And the indicides
    3,7,11
    12,13,14
    I believe are non-uniform scaling, but I have tested them, these should be set to zero.
    Its possible they aren't supported.
    Peter Brinkhuis has written a great article about transformations specific to the solidworks api here
    A lot of it applies to the onshape transform, but the indicies are in a different order.
    the indices
    0,1,2
    4,5,6
    8,9,10
    indicies
    12,13,14
    3,7,11
    And the indicides
    3,7,11
    12,13,14
  • kevin_dolfingkevin_dolfing Member Posts: 5
    Thanks for the good resource @caden_armstrong. However I believe that 12,13 and 14 is the non-uniform scaling and 3, 7 and 11 is the translation array. Reason for this is that I haven't seen a single 3, 7, 11 that has been 0 from the api, while 12,13 and 14 always were. Translation matrix really was a keyword I needed. I will have a go at this
    For those who might see this in the future. I was using Three.js as a renderer and tried using the wrong Matrix4 method. I used Matrix4.fromArray, where I should have used Matrix4.set.
    @kevin_dolfing Yes you are correct.
    I had it confused with the view matrix, which is transposed from the transform matrix.
  • stephanos_androutsellisstephanos_androutsellis Member Posts: 2
    Thank you! That's exactly what I was looking for… :-)
