Unable to join two parts with boolean operation. What am I doing wrong?
I've been trying to join two parts with a boolean operation but it won't work. One of the parts is a dome and think that might be the problem but I'm unable to figure it out. Here is a picture and a link. If anyone could help or point me to a tutorial that shows how to do it that would be great thanks.
_anton Member, Onshape Employees Posts: 444
One of the parts is revolved, the other is extruded, and they're only meeting at one edge - the boolean would produce nonmanifold geometry.
I think the most correct way to fix this is with another revolved part. Then you split it and delete the excess. Like so: https://cad.onshape.com/documents/3a2f20a8f576bf1fd23b5657/w/47efc353d57f38e531cde17b/e/69bd74afd1b5ac983fb96e711
There is a gap on one side as indicated by the arrow. You'll need to modify the geometry so that there's interference between the parts and then you can use the Boolean operation
Here’s a way of using 6 steps to model the entire part.
EDIT Is about adding another Part Studio, for an Assembly with screws, nuts, and washers.
https://cad.onshape.com/documents/386a757644e61c3d322ee53a/w/de12d438076e06edacd0b2c4/e/974124b01fcd2cb0ce3fcd09
