Linear Pattern Extending Tube. - Heat Exchanger
mario_darceuil
Member Posts: 113 ✭✭
During the linear pattern design, the tube is extended longer than in the initial extrude. In the initial extrude the tube is 9 inches but when I perform the linear pattern I get extra length on the tube. Please help me correct this.
Hi @mario_darceuil,
Try changing the "First Fin Extrusion" to "New" instead of "Add". This will allow you to pattern the fin only, without the rod.
RENDERCAD
