Linear Pattern Extending Tube. - Heat Exchanger
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
During the linear pattern design, the tube is extended longer than in the initial extrude. In the initial extrude the tube is 9 inches but when I perform the linear pattern I get extra length on the tube. Please help me correct this.
  • MichaelPascoeMichaelPascoe Member Posts: 2,811 PRO
    Hi @mario_darceuil,
    Try changing the "First Fin Extrusion" to "New" instead of "Add". This will allow you to pattern the fin only, without the rod.
    RENDERCAD
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    Oh! Sounds logical really great I will try. thanks.
    Thank you.
