Hi....I am trying to create a rib feature but unable to get one in given part
harinderjit_singh
Member Posts: 1 ✭✭
brian_brady
Member, Developers Posts: 505 EDU
The hand drawing makes you think this is possible, but it is not, regardless of the CAD system. The rib would either have to overhang due to the curve, resulting in no end surface. Make a symmetric extrude with a triangle sketch and see how the "rib" overhangs. If you make the rib sketch end before the apex of the curve by enough the rib will work.1 -
MichaelPascoe
Member Posts: 2,761 PRO
@brian_brady is right.
However, because the drawing didn't call out the curvature of that ribbed face, we can do anything we want. Like loft the ends of the rib and resurface the top of it:
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1 -
S1mon
Member Posts: 3,914 PRO
You could achieve what's in the drawing with a loft or some sort of surfacing. The tip of the rib can't be a flat plane and share an edge with the cylindrical surface. The tip of the rib will need to go from a slight crown to a flat.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1
