Chamfer magically extends to new surfaces
ty_brown
Member Posts: 4 ✭
Good morning!
I've been using Onshape for years now, and while I seem to run in to issues fairly frequently, it's typically due to the keyboard-to-chair interface (Me).
I'm trying to build a stackable frame, leveraging opposing cuts and ribs that fit in to each other. I'm trying to cut (chamfer) the edge of this floor, while leaving the walls unchanged. Depending on where I click to indicate the chamfer, different walls get included. However, no matter how I cut, lay out guidelines, or mutter curses, I can't get it to chamfer WITHOUT cutting the walls. Heck, I've got the cut set for 2.5mm, but it appears to take much more from the walls (following the created plane).
Is there a way around this? Is this intended behavior? (If so, it would be amazing, if you could somehow exclude/include it with a radio button or something)
I think I know the fix for THIS drawing, but I'm really trying to learn how this works so I can teach others.
Many thanks!
Have you tried unchecking the tangent propagation?
I better understand your issue now. Please vote on this improvement, it is something that is needed for problems like this. https://forum.onshape.com/discussion/19599/add-partial-edge-functionality-to-chamfer-feature#latest
I don’t know if I ever would have speculated that the grooves were giving a problem to the chamfer — but that’s exactly what it was
that is some very nice thinking there Simon
https://cad.onshape.com/documents/84deb3efe2f268cb8271f17f/w/494215775b1a248437be6cdc/e/573decaf94abaa7cf85f65b6
The model is public. I just looked at the name in the screen captures up above and typed that into the public search and it came right up
Hmmmmm. I played with it a bit myself, and it seems to based on the number or location of those grooves on the open side. If I leave these two off, the chamfer still works after the grooves. I really don't understand what the issue is, but it seems to be some sort of weird topology problem. In any case, I would tend to put that chamfer before the holes/grooves anyway.
On a side note, Sketch 6 has 30 X 1mm diam circles. Each one is dimensioned. Unless they might all need to be different sizes later, I would select all of them and make them equal, and only have one diameter dimension. I might consider patterning features instead of making a sketch like that, but it all depends on how the part might need to change later. I'm also not a big fan of imprinting on faces. The selection for Extrude3 is crazy. If you turn off imprinting, and only make the holes/grooves solid lines, there's one selection for Extrude3 -- Sketch 6. Instead there are a zillion faces to select and manage.
Also Sketch 1 has a weird issue at the half circle which is causing a thin sliver of a gap in the part. I'm guessing this is unintentional.
