Using Featurescript...easiest way to add fillets to specific edges of an opRevolve
leti_ryder
Member Posts: 7 EDU
Hi guys!
I am learning Featurescript, and using inputted data to make a bottle like shape. In the script I use opRevolve to make a new body. I want to add a fillet 2/3 edges on this body. How do I select them programmatically for the fillet command?
Thanks!
Thanks!
MichaelPascoe
Member Posts: 2,673 PRO
After the revolve, you can find the revolved entities like this:var revolvedEdges = qCreatedBy(id + "revolve1", EntityType.EDGE);
Then you could do something like this to remove the edge closest to the origin:var closestToOrigin = qClosestTo(revolvedEdges, WORLD_ORIGIN); var edgesToFillet = qSubtraction([revolvedEdges, closestToOrigin]);
In the future, if you ever need to add queries together, you can use qUnion([query1, query2, etc... ]);
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴1
