How do I make a flexible tube? How would I make opposite and separate motions?
jacob_urbina232
Member Posts: 6 ✭
So I was making a syringe hydraulic powered robotic arm and got all of the joints and main syringes set up, but how would I relate/mate the syringes moving the joints to other syringes which would simulate the controls by having one retract when the other extends? Also how do I make a part that is flexible in order to visually connect the controlling and reacting syringe?
Hi @jacob_urbina232, please share a link to your model so we can help you better.
Retracting and extending can be done with mate relations. Specifically the Linear gear.
Flexible parts are not yet supported in Onshape.
Here are some workarounds that may help you with flexible parts:
Split part into multiple sections and place revolute mates and gear relations to simulate flex:
https://forum.onshape.com/discussion/comment/80979#Comment_80979
Animate flex by swapping configurations per frame:
https://forum.onshape.com/discussion/comment/77717#1
RENDERCAD
https://cad.onshape.com/documents/708218c3b3c2aacf5b56920f/w/effa5ee63d3c7c4beca6c4cf/e/8a94c227911dc3e8d837da1c?renderMode=0&uiState=63880cc3b7dceb4302b2ee97
Any of the above methods should work, it will all depend on how much time you want to spend on it.
It is also possible to hide parts and still use them as guides keeping the "hoses" tight. The hoses could use a chain link approach with revolve mates.
RENDERCAD
