How do you create a surface from connected edges--fill() not working?
I am trying to create a surface from an array of edges bounded together forming a region. I am not sure if I am using the fill() function correctly, each time I try to use it I get this error: Precondition failed (surfaceOperationTypePredicate(definition)).
Code:
MichaelPascoe Member Posts: 2,447 PRO
Hi @thomas_lampertius037,
Depending on the type of edge conditions you want, you will need to place the query in the appropriate location: either G0, G1, or G2.
Here is one way you can do this:opFillSurface(context, id + "opFillSurface1", { "edgesG0" : qNothing(), "edgesG1" : NestedPockets2Fix, "edgesG2" : qNothing(), "guideVertices" : qNothing() });
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
@mahir that's legit. I didn't know that. This will save me some if statements.
