Extrude not working.
Hello, Ive been trying to extrude a sketch and every time i attempt to extrude it will not allow me to extrude the outside. It works when I try to extrude shapes i made inside but whenever I try to extrude the outline it wont work. I would love any help possible!
I you need any more details please ask. THANK YOU!
https://butlertech.onshape.com/documents/33443dbfd2ef2b3841bec494/w/e5d10a1bb0c391f98e0fd64a/e/c261ca5a3f6e87056f5729c0: Document
  • S1monS1mon Member Posts: 4,046 PRO
    You'll need to make your document public. You shared a link to your Enterprise.
  • logan_frank664logan_frank664 Member Posts: 4
    I was able to figure it out thank you. It was a problem with an edge to edge connection
