Hide transition lines in a part or assembly
ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
I designed the part below and used several tools to make the shape. As a result, what I called transition lines (maybe the wrong name) appear wherever parts joint to each other or fillets are added. As a view for a screenshot that looks really ugly. The question is: Is there any way to hide those lines in the online version of onshape?
  • glen_dewsburyglen_dewsbury Member Posts: 1,137 PRO
    Shaded with out edges.
  • S1monS1mon Member Posts: 3,498 PRO
    Or you may want to still see the outline and sharp edges, in which case you want to select the Tangent edges item on the same view menu and select hidden.
  • ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
    Great gents!!! Thanks a lot!!
