3D from Excel to Onshape
jacek_zagaja
Member Posts: 47 ✭✭
Below is Excel file with macro:
https://sphericalhorns.net/wp-content/uploads/2021/03/DrBA_JMLC_V303.zip
that computes cross section point cloud with parameters on Sheet1:
Points are on Sheet2 but hard to see gap between step size.
- Min. points per ellipse
- Ellipse step size [mm] - step in Z direction
https://cad.onshape.com/documents/e161fbe2d3ea5f28da279c93/v/be9e27c457dc6f53de95e809/e/8d2acc927cc9433b70245871
https://cad.onshape.com/documents/ae2be4f95e789a8efda1315d/w/3cf31603c523c20e4099c20d/e/8f6f9236b006f146876f5554
The loft is still done manually (and I only used two of your shared tables). But here's a link to another article with a similar challenge including a FeatureScript that creates a loft based on your coordinate data.
https://forum.onshape.com/discussion/19542/spline-plus-cross-sections-for-loft#latest
If still interested, I can give you a hand to do it. It will not be too difficult to automate.
