Make Joint in Sheet Metal
amir_livne
Member Posts: 85 ✭✭
in General
Hi
I'll appreciate if someone can show me how to use "Make Joint" in sheet metal
Thank you
Thank you
https://cad.onshape.com/help/Content/sheetmetalmakejoint.htm?Highlight=make joint
I think I've used it only once it seems to describe it fairly well... do you have an example of what you are trying to achieve?
