transformResultIfNecessary?
S1monS1mon Member Posts: 3,917 PRO
        transformResultIfNecessary(context, id, remainingTransform);
I've noticed this line of code in a bunch of the std library (31 of the 192 tabs). I don't remember this being all over in the past.
Reading in feature.fs there's a large comment about how it enables feature based patterns.
Are there any tricks to using this line correctly in custom features? Any reason for it not to be part of the boilerplate?
  • lanalana Onshape Employees Posts: 753 image
    You've probably also noticed that remaining transform is computed by a call to `getRemainderPatternTransform` . That call is feature dependent - the author of the feature needs to decide which input queries can affect the behavior. Between those those two functions it was as much of a boilerplate as we could manage.
    edited December 2022
    Both getRemainderPatternTransform and transformResultIfNecessary are not possible to add to boilerplate because there are two real questions the feature author needs to answer when getting their feature to work with feature pattern:
    1) What references to provide to
    getRemainderPatternTransform()?
    2) Where in the feature function to call transformResultIfNecessary()?
    The references are needed to avoid double-transforms. If a user patterns just an extrude, we need getRemainderPatternTransform() to return different things when extrude is called each new time. But if a user patterns both a sketch and an extrude, we want getRemainderPatternTransform() to provide different things in sketch(), but just identity transforms in extrude(). This way, the final results are not transformed twice.
    The transformResultIfNecessary() call position depends on the feature. For example, your feature might create some geometry then boolean with a part. In that case you should call transformResultIfNecessary() after the geometry creation but before the boolean. For extrude, it's more complicated than a single call to transformResultIfNecessary(). For instance, the end condition of "up to next" will create different geometry in each patterned extrude.
  • EvanReeseEvanReese Member, Mentor Posts: 2,788 PRO
    Thanks for the answers Kevin and Lana! I'm always curious about that stuff.
