Adding Geometries to already extruded sketch
michal_bartak
Member Posts: 17 ✭
in Drawings
Hello
This is my the first post so greetings to everybody and kudos to devs for this great software.
Some time ago I've learnt that using a single Sketch to create multiple shapes/parts from the single sketch is a powerful tool of onShape.
However, adding overlapping/inner figures to this sketch breaks already extruded parts.
Let's imagine a circle extruded into a cylinder.
After adding another, inner circle to the existing one, the already extruded object changes
My question is: what is the strategy for using shared sketches for multiple objects, but do not break already extruded parts?
The only thing which comes to my mind is to create separate sketches which inherit some objects from the main sketch. but maybe there is something else?
Additional question: is there any way to command onShape to extrude using only specific faces/sketch regions or ignore others? Like in the image above, to extrude only from the outer circle ignoring everything inside?
With regards
With regards
https://cad.onshape.com/documents/eeff86f87f2b3be9ae6915b8/w/c75821c5084576f01fba38b9/e/f545e845aebc8635dc2263e9
