Number variable and Number of element in a sketch.
Hi Onshape people
It would help me a lot to be able to assign a variable to the number of sides of a polygone in a sketch. But it seems that functions such as " inscribed polygon " does not allowed a variable for the number of sides it creates.
Do you have any alternative ?
Thanks for your help
Noah
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    One alternative would be the Shape custom feature:
    RENDERCAD
  • noah_philippe854noah_philippe854 Member Posts: 4
    Thanks for the reply. It is a nice feature. happy to discover it.
    Sadly it won't solve my problem. I'm trying to modelize and parametrize zome in a single document. I'd like to  chang the frequency and shape of the zomes by tweaking some variables.
    edited January 2023
    To have it fully parametric it will be tedious to set up, but possible. Combine the Shape feature with something similar to this variable pattern technique and you should be good to go: https://forum.onshape.com/discussion/comment/86191#Comment_86191
    RENDERCAD
