Exported file ist working - it looks empty. No error messages during export or import.
petr_vlčekpetr_vlček Member Posts: 4
Hello,
I need to export my model to stl. I selected part 1 end exported it. It created file with some size (800 kB), but when I opened it in onshape (or also in Tinkercad) it wrote that import was succesfull, but I cant see the model. There is Part 1 in side tree, but no model. I tried also .obj format, simple model etc, but nothing helped. What can be wrong? Thank you.
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 86
    Maybe just try to zoom in a bit? It seems it is a very small part.
    Principal Technical Services Engineer, EMEAI
  • shawn_crockershawn_crocker Member, OS Professional Posts: 886 PRO
    I just checked and exporting seems to work for me.  is it possible there is mixing up of exported and import unit systems or something?
  • petr_vlčekpetr_vlček Member Posts: 4
    Well, ofcourse I tried to zoom before, but not so much. The issue was in export scale (meteres instead of milimeters). Thank you
