Using the Onshape AR on a Ipad or Pphone
dan_schniersdan_schniers Member Posts: 16 ✭✭
do you see any improvements to the AR on mobile devices like being able to move around the model or zoom in or out and maybe being able to hide specific parts when in a assembly when looking at the AR model. This would be some good enhancements to it to be able to do better collaboration. Great Software
Thank you
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 324
    edited January 2023
    The AR View in the current iPhone app will allow for zoom, rotate,  and repositioning (other than moving yourself of course). There are gestures (pinch to zoom, drag one finger to rotate, and double tap to reposition on a new flat reference). We don't have a way to quickly hide an instance, but have you tried working in collaboration with another user/device? They (or you with your other hand) can be in the same assembly and be making changes (hide/show, edits, insert new instances...)  while the AR Viewer sees the real-time updates. I think that's pretty cool....
  • dan_schniersdan_schniers Member Posts: 16 ✭✭
    Thank you for you quick response.
