How do these surface artifacts appear when 3d printing this onshape part?
kees_bijker
Member Posts: 170 ✭✭
Hello Onshape community,
I did look around for existing questions on this matter, but did not find any, so apologies if I missed it.
I created a part in Onshape, very simple in fact. It has a flat surface without any features at all except 2 ribs growing towards an angled second plane. Fully confined model, no blue lines anywhere. I exported it as STL and printed it.
I use Prusa slicer 2.5 and never have a problem.
This model however shows weird paths on the top surface, resulting in what looks like artifacts that should not be there. In all my years of modeling in Openscad, and now a few weeks in Onshape, I have never seen this ever! Please see the pictures.
I kind of think I did something wrong, since I am only working with Onshape for some weeks, but not sure. Maybe the ribs "grew" into the object rather then to its closes surface. This could have caused an internal feature causing the slicer to interpret is as something other than infill, but again not sure. It does not show anything on the base of this flat part.
By the way the model is totally functional so it has not resulted in a failure. It just looks really bad and if you were to make something that has to look ok on the top surfaces, this would be a failure.
1) screenshot of the slicer showing the artifacts. 2) part in Onshape 3) the print as it happened.
Hi @kees_bijker, Nice project!
I haven't had this happen with my prints. Please share a link to your document so we can take a closer look.
Besides that, +1 to Michael's post.
Strange, the Onshape model looks fine and the STL export seems to be in good condition for my printer software (CHITU Box). You could try exporting it as a Parasolid, then using a 3rd party site to convert it to STL to see if that gives you different results.
Hi S1mon,
