feature request, extend fillets to have a 'dogbone' option
david_lang457
Member Posts: 104 ✭✭✭
in Drawings
when CNC cutting, it's impossible to eliminate a corner radius from parts. The fillet option allows you to round the corner, with the edges of the curve tangent to the sides, but when you have to mate that piece with the corresponding angle that's not rounded, it doesn't work and manual work is needed to make the pieces fit. The 'dogbone' solution to this is to cut a little more in the concave corner to give clearance for the actual angle to fit.
the naieve approach to doing this is to move the cutter so that the center of the cutter is at the corner of the angle, but this is making a much larger cut than is actually needed.
Please consider extending the fillet tool with a checkbox that would instead make the curve touch the corner of the angle (and if the angle is < 90 degrees, have a slot the same width as the diameter of the fillet)
I created an example doc that lets you change the corner angle and shows that angle, and that angle + 90 degrees, comparing this 'dogbone' version to what a fillet would produce.
https://cad.onshape.com/documents/933036b68befc7cadd1faa6d/w/16319fd3e32ea8876de6c23b/e/5e9a31bf32b327c5cf0f251e
I could see adding options for a small tolerance clearance at the sharp, and also an option for adding fillets to get rid of the sharp corners.
https://cad.onshape.com/documents/b99915c0b73924ca981bc57f/v/231175f206330e24f92ddfab/e/aa559abd05b5610c0ffb6b81?jumpToIndex=1871
I think I've seen that before, and it makes a full hole centered on the corner (square or round), what I'm looking for is the easy ability to make a smaller cut in the part.
@S1mon
I am suggesting it as a modification to the fillet tool as the work that's being done is so similar. for angles >= 90 degrees it's just a change to have the curve touch the point instead of having the edges of the curve be tangent to the surfaces. (a little more complex when the angle < 90). I'm trying to avoid yet another special tool to be added to the toolbar :-)
Fillet currently does so many things, adding this option makes perfect sense for your needs, but for many others it would be something that they might never use. It probably wouldn't be that hard to take @MBartlett21's feature and improve it to have the options that you want. That's the beauty of custom feature scripts, and so many of them being public. An extra tool added to your toolbar is a small price to pay for the functionality that you want, but added complexity to the fillet tool that nearly everyone uses in Onshape would bog down a lot more people.
https://cad.onshape.com/documents/578830e4e4b0e65410f9c34e/v/d2bbf038b14307b6c4b70c15/e/7af109b2f1cead90850525ae
