"Tooltip Template" requires "Feature Name Template" to work?
javawizard
Member, csevp Posts: 13 ✭✭
I'm creating an "Import Variables" feature similar to SuperDerive's "Include variables" checkbox but without requiring a part to be imported from a part studio in the same operation.
So far so good: the feature is written and works, but I'm running into an interesting problem while putting some cosmetic touches on the feature: it seems as though the "Tooltip Template" option only works if the "Feature Name Template" option is also specified.
With both options:
The tooltip is rendered as expected:
But with only the "Tooltip Template" and not the "Feature Name Template":
Neither is visible:
My hope is to expose the list of imported variable names as part of the tooltip by using a computed parameter. Is there a way to have a tooltip template without also overriding the feature name?
Example doc: https://cad.onshape.com/documents/ae6f6068533e47c7078c8c28/v/3cf136424fc801660601dc50/e/8f6730aff4d93ffb93e8caec is with both specified (it works), https://cad.onshape.com/documents/ae6f6068533e47c7078c8c28/v/3d183568b176ab2046c66e53/e/8f6730aff4d93ffb93e8caec is with only the tooltip template specified (it doesn't work).
Thanks!
With both options:
Neither is visible:
Thanks!
As far as I'm aware variable studios don't support measured variables - but I would be thrilled to be proven wrong!
(Other options I considered: importing the sketch and measuring it in the second part studio before importing it again into its final position - somewhat annoying because I can't later "delete part" on the sketch because delete part doesn't work on sketches; importing the sketch, measuring it, and then translating it into its final position - doesn't work because the "transform" tool doesn't work on sketches.)
It still doesn't address my original question: why does the "Tooltip Template" FeatureScript annotation not work unless the "Feature Name Template" annotation option is also specified? Is that expected behavior (and why), a bug, or am I annotating my feature wrong in some other way?
