ISO Profiles
amir_livneamir_livne Member Posts: 85 EDU
Hi
I found "Frame" feature very useful but I would like to raise two issues:
1. Rectangle bar dimension are in inches
2. ISO profiles contains only few profiles
Amir Livneh
  • GWS50GWS50 Member Posts: 458 PRO
    Yes I'm afraid the ISO profiles are rather limited. You can use your own profiles by creating sketches but this takes a while to build up your own library.
