Frame end cup
amir_livne
Member Posts: 76 EDU
Hi
Usually when we have to prepare an end cup we use a flat rectangle bar for that purpose.
When we use that option in Onshape we have to give the offset dimension from the profile.
The result is that we receive an end cup with strange dimensions.
I think that Onshape should change it to the same format as in Solidworks
Thanks
Amir Livneh
Thanks
Amir Livneh
My frame is 20X20 mm.
My End cap size is 40X40X5 mm
Seems correct for me
It looks like you have a 3 inch tube. (146.2 - (2 x 35))/25.4 = 3
More than that - in case I would like to add a 40X40mm end cup I expect to write that dimension in the dialog box
