Exported DXF is huge
gary_asplin
Member Posts: 5 EDU
I have set my units of measurement to mm. When I export a dxf to a laser it is 25.4 times bigger. Obviously it is exporting in inches. How do I stop this from happening?
Onshape uses meters for everything "behind the scenes" so it seems unlikely that it would export in inches unless specifically set to these units, are you sure you don't have a setting issue on the import side?
It it's showing up 24.5 times larger it actually means it's exported in mm but interpreted as inches when imported! Maybe try setting your workspace to inches and see if that helps?
Export DXF 2004 instead of the default 2018
Check your Account setting's , are they in mm, they can differ from the document settings..
If Onshape exports something that is 100mm long with a value of "100 units" in the exported file but the software you import it in thinks it's inches, it will read this "100 unit" long thing and interpret it as a 100 inches, or 2540mm!
If Onshape was exporting in inches, then it would make something 25.4 mm long "1 unit" in the exported file and if you imported that assuming it was mm you would get something 1mm long!
Many software use this parameter to 'pick' the units the dxf is supposedly in, especially automatic quoting software and random laser cutter software as discussed.
This is the problem. "insunits" parameter in the dxf file not being set to metric. Open the file in a text editor and change that parameter so it represents metric (can't recall if it were a 1 or 0 setting)
I was struggling trying to use the exported DXF file in bCNC, and was forced to scale them each time by using its operations once imported. Which is a real PITA as you can imagine.
As suggested by several users, I've checked and both the workspace and the document units are set to mm. I've also tried different DXF versions in the export dialog, by no way. I confess not having tried all of them, but at least all the ones that were suggested here and there.
Changing :
$INSUNITS 70 1 9to :$INSUNITS 70 4 9in my favorite text editor did the trick.Note: 1 means inches and 4 means mm.
This looks like a bug in the DXF export process, which doesn't seem to take into account the current settings.
In the meantime I'll try to write a small Python script to edit the DXF with the help of the appropriate package.
