Improvements to Onshape - February 3rd, 2023
2»
  • don_williams909don_williams909 Member Posts: 148 PRO
    Still waiting for the Arial font...
  • mike_hölschermike_hölscher Member Posts: 110 ✭✭✭✭
    NeilCooke said:
    Is there a different between Extrude Offset and just flipping the Second end position direction? I have been using that since the beginning to do Extrude Offsets.
    Hi Mike, there are quite a few differences and there was a crazy amount of votes for this improvement - mainly, you don't have to do any mental maths to work out the second offset and you can apply draft from the offset plane. My main use case is when detailing bosses where the top of the boss is the critical dimension and then draft is applied from there. You can now sketch on the bottom face, offset and extrude/draft backwards up to next.
    Thanks for the answer @NeilCooke! I have been playing with it this morning and I must admit it saves me some brain activity like you mentioned. I also noticed the second end position also starts with this offset now, interesting. I expected it to be separate, with a separate offset in the second direction, but maybe it is better as it is now. Looking forward to finding out how this change works in practice. Fun fact: I remember asking the Onshape Succes Manager in 2017 how to Extrude Offset and an engineer was brought into the call to tell me how to use second end position for this. It was one of the first questions I asked  :D
    Also, the Improvement Request forum section is quite a friend of mine, but I have never seen this Extrude Offset request. Cannot find it right now also... Crazy amount of votes you say?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,087 PRO
    Nice update, Glad to have hatches in drawings, and MATE FOLDERS!
    One thing I see on the change log that wasn't mentioned is updating drawings from the version dialog actually works again!
    Tested it on a document that doesn't update usually, and it worked. Awesome! I missed not having that feature.
  • SethFSethF Member Posts: 132 ✭✭✭
    Either that... Or a nemesis... Why is he SO SAD??
    MichaelPascoe said:
    @SethF Our friend has a henchman.
    Hi mike_hölscher,
    We pull from both public requests/votes in the Improvement Request forum as well as private requests tracked with the same mechanism as our support tickets.  In the case of Extrude Offset, there was nothing in the Improvement Request forum that we were pulling from.
    Jake Ramsley
  • S1monS1mon Member Posts: 4,299 PRO
    I still haven't dug into the new Extrude options, but it sounds like it solves this issue:
    https://forum.onshape.com/discussion/14457/extrude-from-vertex
    There's an improvement request:
    https://forum.onshape.com/discussion/5446/extrude-from
    It was marked as already offered - which kinda missed the point.
    The big miss with how it worked up until this new update, was that extruding with draft (even with second direction) used the sketch plane as the draft hinge. To me this was always a huge disappointment. I was so used to doing injection molded parts (in Solidworks) with many sketches on the default planes, and extruding from/to with draft.
  • Josiah_HarthcockJosiah_Harthcock Member Posts: 57 PRO
    Love it! Great job guys!
  • Shubham_MishraShubham_Mishra Member Posts: 4 PRO
    Good work on Hatches, waiting to see more capabilities (non-linear studies and thermal) added to FEA simulation.
  • Theo_RTheo_R Member Posts: 82 PRO
    Great update!
  • JollyJolly Member Posts: 81 PRO
    edited February 2023
    Mate Folders! Kermit-waving-hands-excitedly.meme
    But this update has a host of awesome improvements. Very nice!
  • JosefBurjetaJosefBurjeta Member Posts: 30 PRO
    @S1mon thanks for the explanation of Color maps, did not try to Merge them before, but it works. I was used to fixed orientation of surfaces, but I really like how it automatically changes depending on the state of another surfaces.
    Didn't the Fill switch do Add? As it basically does when you try to create a surface from edges of another. I've noticed that since the Feature turned red and first I had no idea why, because I added the correct value for each side. Then I saw it's Add not New.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,228 PRO
    I just tried extrude offset. I like it a lot. The same functionality was currently there but it took a lot more clicks and thinking to get it. (extrude to surface plus offsets in both directions. Getting the main + offset directions correct was always hit or miss).
    NeilCooke said:
    ..snip.... My main use case is when detailing bosses where the top of the boss is the critical dimension and then draft is applied from there. You can now sketch on the bottom face, offset and extrude/draft backwards up to next.
    Pretty please with a cherry on top do the same with the hole command:)
     I see some new buttons (that disappeared on refresh):
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,068 image
    You weren’t supposed to see those!
  • Phillip_BPhillip_B Member Posts: 34 PRO
    Will we see a new update today or can I get back to work?  :p
     :D
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 1,024 ✭✭✭✭✭
    Bryan Lagrange
    Twitter: @BryanLAGdesign
