Convert text to shapes / lines?
I need to make additional sketch elements atop some text in a sketch. E.g. to connect the inner of an "O" to the outer. But it seems like the text element is not "really a sketch" which I can interact with. I can draw on top of it but I can't reference any part of the text to be included in a constraint.
When I try to draw a "stem" across the "O", the intersections to not create points, and so I cannot e.g. trim the loose ends. What am I missing here?
  • S1monS1mon Member Posts: 3,391 PRO
    You don't need to trim the curves to create the extrusions you want. Sketch faces are created anyway. You can then select the faces to extrude.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 667 EDU
    ^ that's the best solution.  Also, for future reference, exporting a sketch as a DXF and then importing that DXF into a new sketch will create sketch entities.
  • eric_pestyeric_pesty Member Posts: 2,272 PRO
    You could also just extrude the entire letters and do as second feature to "merge" them back in...
  • josh_mccullough080josh_mccullough080 Member Posts: 24
    Thanks. The main issue is not about selecting the faces, but rather selecting constraint references. For instance, I want those lines to be parallel to the upright portion of the "d" (not pictured). But I can only select all of the "d", not just a single line. The text is rotated which also makes things a bit more difficult.
    I'm putting it back to horizontal and I will apply the rotation in the Wrap step, rather than at sketch-time. I think this will get me the rest of the way there. Thanks again.
    If you need to reference edges to get angles or sizes of letters, I would follow @eric_pesty 's suggestion. Keep in mind you can do things like make helper parts or surfaces that you then use the edges of to create a sketch later.
