ARbase add-on
Hello
I have a problem with the ARbase add-on.
Installed it from the store but can't find it in my applications
What am I doing wrong?
  • MichaelPascoeMichaelPascoe Member Posts: 2,807 PRO
    edited February 2023
    Hi @geppetto_sepp, ARbase has a special button over on the right side of your screen. However, as of Improvements to Onshape 10-10-2022, this application is not needed anymore because Onshape now supports AR View directly with the latest Apple devices:
    Onshape's AR View
    In case you still need it, ARbase should appear over on the right side of your part studio:
    RENDERCAD
  • geppetto_seppgeppetto_sepp Member Posts: 6
    Hi Michael
    Thanks for your answer, unfortunately I don't have an IOS.
    I've found ARbase now, but I can't set borders there, only a component color. Or am I seeing the bottle?
    Improvements to Onshape - October 10th, 2022 — Onshape
    Where can I find this ? When I click on the cube, the menu doesn't come up.
    @AlanKalbfleisch, may be able to help with this. I believe he is the creator of this neat app.
    RENDERCAD
